Панель управления
v3.5
История изменений Панели управления ONLYOFFICE
Version 3.5.2
Release date: 02/29/2024
- Added the ability to restrict access rights to the application files for the Others group.
- Fixed issue with redirect to the portal main page when opening Control Panel after a day on Ubuntu 22.10.
- Fixed retrieving data error when opening the backup page.
- Fixed issue when backup with Mail is not performed after disabling and enabling encryption (added text about stopping services and the instruction to the Help Center).
- Fixed issue when features are not saved to the new tariff when setting a quota for the portal.
- Edited sources build.
Version 3.5
Release date: 03/14/2023
- Changed API methods for migration, implemented progressQueue.
- Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3.
- Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab.
- Added the ability to set the portal memory quota.
Version 3.1.1
Release date: 08/08/2022
- Fixed issue with file indexing.
- Fixed elasticsearch container errors when updating ONLYOFFICE Groups.
- Fixed issue with brand logos after updating in the Docker installation.
- Fixed texts and layout for the Migration feature.
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js, updated packages (transition to samlify for SSO);
- Added the
upgrade page with a proposal to upgrade to Enterprise Edition;
- Added the
activate page with a possibility to upload a license file;
- Transition to the new
samlify library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777;
- Fixed the
Invalid authentication token error which prevented from adding a user to the portal using the AD FS, in case the + or - characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown value or the ldap.domain value from the web.appsettings.config configuration file;
Sizelimit Exceeded error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute;
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth service;
Version 2.0.0
Release date: 05/25/2017
MVC to Node.js.
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Если вы только что развернули на своем сервереваш тарифный план облачной версии поддерживает это, то первое, что надо сделать, - это создать учетные записи для всех сотрудников компании. Если она насчитывает более 50 человек, создание новых пользователей портала займет много времени.
В Панели управленияНа вашем портале доступна опция Настройки LDAP, которая позволяет буквально за несколько минут импортировать в онлайн-офис нужных пользователей и группы с сервера LDAP (например, OpenLDAP Server или Microsoft Active Directory). В свою очередь, новым пользователям не придется запоминать новые логины и пароли, поскольку они смогут заходить на портал под своими учетными данными, сохраненными на сервере LDAP.
Чтобы открыть Панель управления, войдите на портал и нажмите на ссылку 'Панель управления' на Стартовой странице. Можно также перейти в 'Настройки' портала и нажать на ссылку 'Панель управления' на левой боковой панели.Перейдите в Настройки портала и нажмите ссылку 'Настройки LDAP' в разделе Интеграция.
Импорт пользователей и групп
Перед началом импорта
Если вы подключаетесь к базе данных Active Directory, которая содержит более 1000 пользователей, вам потребуется увеличить лимит AD
MaxPageSize = 1000 с помощью утилиты
ntdsutil. Подробные инструкции о том, как это можно сделать, доступны
здесь.
- В Панели управления откройте страницу LDAP в разделе НАСТРОЙКИ ПОРТАЛАВ Настройках портала откройте страницу Настройки LDAP в разделе Интеграция на левой боковой панели.
- Нажмите на переключатель Включить аутентификацию LDAP (если вы меняете настройки повторно, используйте ссылку Показать рядом с заголовком Настройки LDAP, чтобы отобразить форму для ввода параметров).
- Установите флажок Включить StartTLSStartTLS, если вы хотите обеспечить безопасное соединение с помощью технологии StartTLS (в этом случае используется стандартный порт 389). Установите флажок Включить SSL, если хотите использовать протокол SSL (в этом случае номер порта автоматически изменится на 636).
- Заполните поля, необходимые для импорта пользователей (обязательные поля помечены звездочкой):
Внимание
Обратите внимание, что в случае, если вы уже импортировали каких-то пользователей и меняете настройки (например, Сервер, Фильтр пользователей, DN каталога пользователей, Фильтр групп, DN каталога групп), существующие пользователи и все их данные, включая документы, сообщение электронной почты, другие, отсеянные новыми настройками, будут ОТКЛЮЧЕНЫ. Мы настоятельно рекомендуем сделать резервное копирование данных, прежде чем вы измените какие-либо настройки.
- в поле Сервер введите URL-адрес сервера LDAP в формате protocol://host, например, LDAP://example.com для обычного соединения с сервером LDAP или LDAPS://example.com для безопасного соединения с сервером LDAP по протоколу SSL. Вместо доменного имени можно также указать IP-адрес сервера: LDAP://192.168.3.202,
- укажите Номер порта, используемый для соединения с сервером LDAP. Для обычного соединения с сервером LDAP по умолчанию используется порт 389. Если вы включили опцию StartTLS, также используется стандартный порт 389. Если включена опция SSL, номер порта автоматически изменяется на 636.
- в поле DN каталога пользователей (англ. User Distinguished Name) укажите абсолютный путь к каталогу верхнего уровня, содержащему пользователей, которых требуется импортировать. Этот параметр определяет узел, с которого начинается поиск. Можно указать корневой каталог, например,
dc=example,dc=com, чтобы осуществлять поиск пользователей по всему каталогу, или задать определенную область поиска, например, ou=groupname,dc=example,dc=com, чтобы осуществлять поиск пользователей внутри указанной группы.
- укажите Атрибут логина (атрибут в записи пользователя, соответствующий логину, который пользователи сервера LDAP будут использовать для входа в ONLYOFFICE);
Пожалуйста, обратите внимание: настройки по умолчанию указаны для
Active Directory. Для
OpenLDAP Server необходимо изменить следующие настройки:
- Фильтр пользователей -
(uid=*)
- Атрибут логина -
uid
- заполните поле Фильтр пользователей, если необходимо импортировать пользователей, соответствующих указанным критериям поиска. Значение фильтра, заданное по умолчанию
(uid=*), позволяет импортировать всех пользователей.
Примеры синтаксиса фильтра поиска можно посмотреть
здесь.
- укажите Атрибут логина (атрибут в записи пользователя, соответствующий логину, который пользователи сервера LDAP будут использовать для входа в ONLYOFFICE).
OpenLDAP Server. Для
Active Directory необходимо изменить следующие настройки:
(userPrincipalName=*)
- Атрибут логина -
sAMAccountName
- В разделе Сопоставление атрибутов можно установить соответствие между полями с данными пользователя на портале и атрибутами в записи пользователя на сервере LDAP. Нажмите кнопку Добавить атрибут, выберите из списка нужное поле данных и укажите атрибут пользователя, используемый на вашем сервере LDAP. Значения следующих параметров заданы по умолчанию, но в случае необходимости их можно изменить:
- Имя (атрибут в записи пользователя, соответствующий имени пользователя)
- Фамилия (атрибут в записи пользователя, соответствующий фамилии пользователя)
- Почта (атрибут в записи пользователя, соответствующий адресу электронной почты пользователя)
- Должность (атрибут в записи пользователя, соответствующий должности пользователя)
- Основной мобильный телефон (атрибут в записи пользователя, соответствующий номеру мобильного телефона пользователя)
- Местоположение (атрибут в записи пользователя, соответствующий местоположению пользователя)
Вы также можете добавить следующие атрибуты: Дополнительная почта, Дополнительный мобильный телефон, Дополнительный телефон, Дата рождения, Фото профиля, Пол, Skype.Дата рождения, Пол, Фото профиля, Дополнительный телефон, Дополнительный мобильный телефон, Дополнительная почта, Skype.
- Нажмите на переключатель Принадлежность к группе, если вы хотите добавить на портал группы с сервера LDAP, и заполните нужные поля:
Пожалуйста, обратите внимание: если вы решите добавить группы, будут добавлены только те пользователи, которые состоят хотя бы в одной группе.
Внимание
- в поле DN каталога групп (англ. Group Distinguished Name) укажите абсолютный путь к каталогу верхнего уровня, содержащему группы, которые требуется импортировать, например,
ou=Groups,dc=example,dc=com.
- заполните поле Фильтр групп, если необходимо импортировать группы, соответствующие указанным критериям поиска. Значение фильтра, заданное по умолчанию
(objectClass=posixGroup), позволяет импортировать все группы.
- значения следующих параметров заданы по умолчанию, но в случае необходимости их можно изменить:
- Атрибут пользователя (атрибут, который определяет, состоит ли этот пользователь в группах)
- Атрибут названия группы (атрибут, который соответствует названию группы, в которой состоит пользователь)
- Атрибут группы (атрибут, который указывает, какие пользователи состоят в этой группе)
- Фильтр групп -
(objectClass=group)
- Атрибут пользователя -
distinguishedName
- Атрибут группы -
member
- Атрибут пользователя (атрибут, который определяет, состоит ли этот пользователь в группах);
(objectClass=group), позволяет импортировать все группы;
- Фильтр групп -
uid
- Атрибут группы -
memberUid
- Задайте Настройки прав администратора: нажмите на соответствующую кнопку, выберите полный доступ и укажите группу, которая должна иметь права администраторов с полным доступом. Выберите из списка какой-либо модуль портала и укажите группу, у которой должны быть права администратора в выбранном модуле.
- Включите переключатель Аутентификация пользователей, если у текущего пользователя Windows нет прав на чтение из LDAP server/Active Directory. В полях Логин и Пароль введите учетные данные пользователя, у которого есть права на чтение данных с сервера LDAP (по умолчанию используются логин и пароль текущей сессии Windows).
- Отметьте опцию Отправить пригласительное письмо в разделе Дополнительные параметры, если вы хотите отправить приглашения по электронной почте всем новым пользователям. Пригласительное письмо содержит кнопку для перехода на страницу логина и активации адреса электронной почты. Эта возможность доступна только если настроено сопоставление атрибута почты.
- Нажмите кнопку СОХРАНИТЬ.
- В открывшемся окне 'Подтверждение импорта' нажмите кнопку OK, чтобы начать импорт пользователей.
Импорт займет некоторое время в зависимости от количества пользователей, групп, технических характеристик компьютера и т.д.
Пожалуйста, обратите внимание: адрес электронной почты пользователя портала будет взят из настройки
Атрибут почты. Если он отсутствует, то он будет формироваться следующим образом:
Атрибут логина + @ + Домен LDAP.
- Если на портале есть ранее созданный пользователь с таким адресом электронной почты, этот пользователь автоматически будет синхронизирован с LDAP-пользователем.
- Если такой адрес электронной почты не существует, пользователь не будет получать никаких оповещений с портала.
Начиная с версии Сервера совместной работы v. 10.0SaaS v. 11.5, есть следующие особенности:
- владелец портала не затрагивается изменениями прав доступа через LDAP;
- при исключении из фильтра пользователей или групп владелец портала перестает быть LDAP-пользователем, но всегда остается активным;
- при выключении LDAP все выданные через LDAP права доступа отбираются у пользователей;
- если пользователь, выключивший LDAP, должен был лишиться прав, права остаются, но пользователь получает уведомление о попытке снять с себя права;
- при исключении себя из фильтра пользователей/групп, пользователь остается активным и получает уведомление о том, что LDAP-пароль недействителен и пользователю нужно сменить пароль в настройках профиля;
- при попытке снять с себя права (и через раздел прав, и при исключении себя из фильтра), пользователь сохраняет права и получает уведомление о попытке снять с себя права.
Аутентификация LDAP-пользователей
Каждый импортированный пользователь сможет заходить на портал, используя логин, формируемый по следующим схемам:
- Атрибут логина, например
Andrew.Stone
- Атрибут логина + @ + Домен LDAP, например
Andrew.Stone@example.com
- Домен LDAP + \ + Атрибут логина (поддерживаются неполные имена доменов), например
example\Andrew.Stone
На странице авторизации доступна опция Войти в домен для передачи пароля в явном виде. Пользователи портала не из домена могут отключить эту настройку. В таком случае пароль будет передаваться в хешированном виде.
Профили импортированных пользователей в модуле Люди будут отмечены значком LDAP для администратора портала. Поля профиля пользователя, импортированные по LDAP, заблокированы для редактирования.
Синхронизация данных LDAP
Если вы измените данные на сервере LDAP (например, добавите новых пользователей или группы, переименуете существующие группы или отредактируете какую-то информацию в записи пользователя), данные на портале можно легко синхронизировать с новой информацией с LDAP-сервера.
Чтобы настроить параметры синхронизации, включите переключатель Автоматическая синхронизация и задайте нужное время выполнения автоматической синхронизации: данные можно синхронизировать каждый час в указанные минуты, каждый день в указанное время, а также каждую неделю или месяц в указанный день и время. Нажмите кнопку Сохранить, чтобы применить настройки. Также можно синхронизировать данные вручную, нажав кнопку СИНХРОНИЗИРОВАТЬСинхронизировать пользователей внизу страницы LDAP. Можно также использовать кнопку СОХРАНИТЬ внизу раздела Настройки LDAP.
Информация об отдельном пользователе также будет синхронизирована после того, как этот пользователь войдет на портал.
