Панель управления
v3.5
История изменений Панели управления ONLYOFFICE
Version 3.5.2
Release date: 02/29/2024
- Added the ability to restrict access rights to the application files for the Others group.
- Fixed issue with redirect to the portal main page when opening Control Panel after a day on Ubuntu 22.10.
- Fixed retrieving data error when opening the backup page.
- Fixed issue when backup with Mail is not performed after disabling and enabling encryption (added text about stopping services and the instruction to the Help Center).
- Fixed issue when features are not saved to the new tariff when setting a quota for the portal.
- Edited sources build.
Version 3.5
Release date: 03/14/2023
- Changed API methods for migration, implemented progressQueue.
- Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3.
- Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab.
- Added the ability to set the portal memory quota.
Version 3.1.1
Release date: 08/08/2022
- Fixed issue with file indexing.
- Fixed elasticsearch container errors when updating ONLYOFFICE Groups.
- Fixed issue with brand logos after updating in the Docker installation.
- Fixed texts and layout for the Migration feature.
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js, updated packages (transition to samlify for SSO);
- Added the
upgrade page with a proposal to upgrade to Enterprise Edition;
- Added the
activate page with a possibility to upload a license file;
- Transition to the new
samlify library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777;
- Fixed the
Invalid authentication token error which prevented from adding a user to the portal using the AD FS, in case the + or - characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown value or the ldap.domain value from the web.appsettings.config configuration file;
Sizelimit Exceeded error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute;
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth service;
Version 2.0.0
Release date: 05/25/2017
MVC to Node.js.
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
C помощью функции Брендинг, доступной в Панели управления, вы легко можете заменить элементы фирменного стиля, которые используются в интерфейсе онлайн-офиса, и настроить внешний вид портала в соответствии с брендом вашей компании:
- используйте название вашей компании в текстовых элементах, таких как подсказки, окна сообщений и т.д.,
- замените используемые по умолчанию логотипы и иконку сайта на свой собственный логотип,
- измените информацию, отображаемую в окне О программе,
- скройте или покажите ссылки на внешние ресурсы, такие как форма обращения в техническую поддержку, справочный центр и т.д.
Настройки брендинга можно применить ко всем порталам или только к текущему порталу.
Чтобы открыть Панель управления, войдите на портал и нажмите на ссылку 'Панель управления' на Стартовой странице. Можно также перейти в 'Настройки' портала и нажать на ссылку 'Панель управления' на левой боковой панели.
Изменение элементов брендинга для всех порталов
Раздел ОБЩИЕ НАСТРОЙКИ позволяет изменить настройки для всех порталов.
Откройте страницу Брендинг в разделе ОБЩИЕ НАСТРОЙКИ на левой боковой панели. Вы можете изменить базовые и расширенные настройки брендинга.
Изменение базовых настроек брендинга
Вкладка БАЗОВЫЕ открывается по умолчанию. Здесь можно изменить название компании и заменить логотипы.
- Введите Название компании в текстовом поле ввода, чтобы изменить в интерфейсе онлайн-офиса все надписи и сообщения, в которых использовано значение по умолчанию, заменив его на указанное вами значение. Нажмите кнопку ИСПОЛЬЗОВАТЬ КАК ЛОГОТИП справа от поля ввода, если вы хотите использовать название вашей компании в качестве текстового логотипа (вместо графического логотипа) - все представленные ниже логотипы изменятся соответствующим образом.
- Замените все графические Логотипы, которые встречаются в онлайн-офисе:
Рекомендуется использовать изображения в формате PNG с прозрачным фоном. Чтобы улучшить читаемость логотипов и сделать их контур четко различимым, их также необходимо адаптировать под темные или светлые фоны. Размеры изображений должны точно соответствовать размерам, указанным рядом с каждым логотипом.
- Логотип для шапки редакторов (172x40) (доступно только для платной серверной версии) - этот логотип находится в левом верхнем углу запущенных онлайн-редакторов. Первый, второй и третий логотипы используются для редакторов документов, таблиц и презентаций соответственно, если включена светлая тема, четвертый логотип используется для всех редакторов, если включена темная тема.
- Логотип для шапки редакторов - встроенный режим (172x40) (доступно только для платной серверной версии) - этот логотип находится в левом верхнем углу документов портала, встроенных в веб-страницы.
- Логотип для шапки портала (284x46) - этот логотип находится в левом верхнем углу любой страницы портала.
- Логотип для страницы входа - светлая тема (432x70) - этот логотип находится на странице Входа на портал, используется, если включена светлая тема.
- Логотип для страницы входа - темная тема (432x70) - этот логотип находится на странице Входа на портал, используется, если включена темная тема.
- Иконка сайта (32x32) - этот логотип находится в адресной строке или вкладке браузера, когда портал открыт в нем, или на панели закладок, если вы добавили адрес портала в закладки.
Нажмите на кнопку ИЗМЕНИТЬ справа от логотипа, который надо заменить. В открывшемся окне выберите нужный графический файл и нажмите кнопку Открыть. Изображение будет загружено и отображено в поле соответствующего Логотипа.
- нажмите кнопку СОХРАНИТЬ внизу страницы, чтобы заданные настройки вступили в силу.
Для возврата к настройкам по умолчанию нажмите кнопку НАСТРОЙКИ ПО УМОЛЧАНИЮ.
Изменение расширенных настроек брендинга
Перейдите на вкладку РАСШИРЕННЫЕ страницы Брендинг в разделе ОБЩИЕ НАСТРОЙКИ. Здесь можно изменить информацию, отображаемую в окне О программе и скрыть ссылки на внешние ресурсы.
Раздел Настройки информации о компании используется, чтобы указать сведения о вашей компании, отображаемые в окне О программе на портале и на странице О программе в онлайн-редакторах.
- Замените логотип для страницы О программе:
- Логотип для страницы "О программе" - светлая тема (432x70) - этот логотип находится на странице портала О программе (профиль пользователя -> О программе) и на странице О программе в онлайн-редакторах, используется, если включена светлая тема.
- Логотип для страницы "О программе" - темная тема (432x70) - этот логотип находится на странице портала О программе (профиль пользователя -> О программе) и на странице О программе в онлайн-редакторах, используется, если включена темная тема.
- Введите название компании, адрес электронной почты, номер телефона, URL-адрес сайта и почтовый адрес в соответствующие поля.
- Нажмите кнопку СОХРАНИТЬ внизу этого раздела.
Раздел Дополнительные ресурсы используется, чтобы выбрать, надо ли отображать ссылки на дополнительные ресурсы во всех модулях портала и примеры документов в модуле Документы.
- Снимите пометку с тех элементов, которые вы хотите скрыть, и оставьте отмеченными те, которые хотите показывать:
- Показывать ссылку Обратная связь и поддержка - используется, чтобы скрыть или показать ссылку на страницу с формой обращения в службу поддержки, которая используется, чтобы связаться со службой поддержки ONLYOFFICE.
- Показывать примеры документов - используется, чтобы скрыть или показать примеры документов в модуле Документы.
- Показывать ссылку на видео гайды - используется, чтобы скрыть или показать ссылку на страницу с обучающим видео.
- Показывать ссылку на Справочный центр - используется, чтобы скрыть или показать ссылку на страницу Справочного центра.
Изменение элементов брендинга для текущего портала
Раздел НАСТРОЙКИ ПОРТАЛА позволяет изменить настройки только для текущего портала.
Перейдите в Панель управления на нужном портале и откройте страницу Брендинг в разделе НАСТРОЙКИ ПОРТАЛА на левой боковой панели.
Здесь можно изменить базовые настройки брендинга для текущего портала. Эти настройки аналогичны тем, что содержатся на вкладке БАЗОВЫЕ в разделе ОБЩИЕ НАСТРОЙКИ. Расширенные настройки брендинга недоступны для текущего портала и могут быть изменены только для всех порталов.
