Control Panel
v3.5
ONLYOFFICE Control Panel changelog
Version 3.5.2
Release date: 02/29/2024
- Added the ability to restrict access rights to the application files for the Others group.
- Fixed issue with redirect to the portal main page when opening Control Panel after a day on Ubuntu 22.10.
- Fixed retrieving data error when opening the backup page.
- Fixed issue when backup with Mail is not performed after disabling and enabling encryption (added text about stopping services and the instruction to the Help Center).
- Fixed issue when features are not saved to the new tariff when setting a quota for the portal.
- Edited sources build.
Version 3.5
Release date: 03/14/2023
- Changed API methods for migration, implemented progressQueue.
- Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3.
- Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab.
- Added the ability to set the portal memory quota.
Version 3.1.1
Release date: 08/08/2022
- Fixed issue with file indexing.
- Fixed elasticsearch container errors when updating ONLYOFFICE Groups.
- Fixed issue with brand logos after updating in the Docker installation.
- Fixed texts and layout for the Migration feature.
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js, updated packages (transition to samlify for SSO);
- Added the
upgrade page with a proposal to upgrade to Enterprise Edition;
- Added the
activate page with a possibility to upload a license file;
- Transition to the new
samlify library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777;
- Fixed the
Invalid authentication token error which prevented from adding a user to the portal using the AD FS, in case the + or - characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown value or the ldap.domain value from the web.appsettings.config configuration file;
Sizelimit Exceeded error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute;
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth service;
Version 2.0.0
Release date: 05/25/2017
MVC to Node.js.
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
With the Branding feature provided by the Control Panel, you can easily replace branding elements used in the online office interface and customize the look of the portal according to your company brand:
- use your company name in the text elements, such as tooltips, message boxes etc.,
- replace the default favicon and logos with your own logo,
- change the information displayed in the About this program window,
- hide or show links to external resources, such as Feedback and Support form, Help Center etc.
Branding settings can be applied to all portals or to the current portal only.
To access Control Panel, sign in to your portal and click the 'Control Panel' link on the Start Page. Alternatively, you can go to the portal 'Settings' and click the 'Control Panel' link on the left-side panel.
Changing branding elements for all portals
The COMMON SETTINGS section allows you to change settings for all your portals.
Open the Branding page in the COMMON SETTINGS section on the left sidebar. You can change basic and advanced branding settings.
Changing basic branding settings
The BASIC tab is opened by default. Here you can change the company name and replace logos.
- Enter your Company name in the text entry field to change all the titles and messages in the online office interface where the default value is used replacing it with the one you specified. Click the USE AS LOGO button to the right of the entry field if you want to use your company name as a text logo (instead of an image logo) - all the logos below will change correspondingly.
- Replace all the image Logos which appear in the online office:
We recommended that you use images in the PNG format with a transparent background. To improve your logos legibility and make their outline clearly distinguishable, you also need to optimize them for use on dark or light backgrounds. The image sizes must strictly correspond to the sizes specified next to each logo.
- Logo for the editor headers (172x40) (available for the paid server version only) - this logo appears in the upper left corner of the online editors launched. The first, second and third logos are used for document, spreadsheet and presentation editors correspondingly if the light theme is enabled, the fourth logo is used for all editors if the dark theme is enabled.
- Logo for the editors header - embedded mode (172x40) (available for the paid server version only) - this logo appears in the upper left corner of your portal documents embedded into web pages.
- Logo for the portal header (284x46) - this logo appears in the upper left corner of every portal page.
- Logo for the Login page - light theme (432x70) - this logo appears on the Sign In page of the portal, is used if the light theme is enabled.
- Logo for the Login page - dark theme (432x70) - this logo appears on the Sign In page of the portal, is used if the dark theme is enabled.
- Favicon (32x32) - this logo appears in the address bar or tab of a web browser when the portal is opened in it, or on the bookmarks panel if you've added the portal address to the bookmarks.
Click the CHANGE button to the right of the logo you want to replace. In the window that opens, browse for the necessary image file and click the Open button. The image will be loaded and displayed in the corresponding Logo field.
- click the SAVE button at the bottom of the page to make the parameters you set take effect.
To return to the default settings, click the RESTORE DEFAULT button.
Changing advanced branding settings
Switch to the ADVANCED tab of the Branding page in the COMMON SETTINGS section. Here you can change the information displayed in the About this program window and hide links to external resources.
The Company info settings section is used to specify your company information displayed in the About this program window on the portal and on the About page in the online editors.
- Replace the logo for the About page:
- Logo for the About page - light theme (432x70) - this logo appears on the About page of the portal (user profile -> About this program), and the About page in the online editors, is used if the light theme is enabled.
- Logo for the About page - dark theme (432x70) - this logo appears on the About page of the portal (user profile -> About this program), and the About page in the online editors, is used if the dark theme is enabled.
- Enter your company name, email address, phone number, website URL address and postal address into the corresponding fields.
- Click the SAVE button at the bottom of this section.
The Additional resources section is used to choose if you want to display links to additional resources in all portal modules and sample documents in the Documents module.
- Uncheck the elements you want to hide and leave checked the ones you want to display:
- Show Feedback & Support link - is used to hide or show the link to the Feedback and Support form which is used to contact the ONLYOFFICE support team.
- Show sample documents - is used to hide or show sample documents in the Documents module.
- Show link to Video Guides - is used to hide or show the link to the web page with training videos.
- Show link to Help Center - is used to hide or show the link to the Help Center page.
Changing branding elements for the current portal
The PORTAL SETTINGS section allows you to change settings for the current portal only.
Switch to the Control Panel within the necessary portal and open the Branding page in the PORTAL SETTINGS section on the left sidebar.
Here you can change basic branding settings for your current portal. The settings are similar to those contained in the BASIC settings tab within the COMMON SETTINGS section. Advanced branding settings are not available for the current portal and can be changed for all portals only.
