Chiudi Centro assistenza User guides ONLYOFFICE Workspace General questions ONLYOFFICE Groups ONLYOFFICE Docs ONLYOFFICE Mail ONLYOFFICE Talk ONLYOFFICE Groups Documents Module People Module Community Module CRM Module Projects Module Mail Module Calendar Module Feed Tool ONLYOFFICE Docs All Editors Document Editor Spreadsheet Editor Presentation Editor PDF Editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors ONLYOFFICE DocSpace Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors User Guides Watch video Previous How to connect ONLYOFFICE Documents for Android to Cloud How to connect ONLYOFFICE Documents for Android to Server How to edit documents stored on Nextcloud with ONLYOFFICE on your Android device ONLYOFFICE Documents for Android Document Editor overview ONLYOFFICE Documents for Android Spreadsheet Editor overview ONLYOFFICE Documents for Android Presentation Editor overview How to open and save docs to different formats using ONLYOFFICE Documents for Android How to share files using ONLYOFFICE Documents for Android How to connect ONLYOFFICE Documents for Android to Cloud How to connect ONLYOFFICE Documents for Android to Server How to edit documents stored on Nextcloud with ONLYOFFICE on your Android device ONLYOFFICE Documents for Android Document Editor overview ONLYOFFICE Documents for Android Spreadsheet Editor overview ONLYOFFICE Documents for Android Presentation Editor overview Next ONLYOFFICE Documents for Android Mostra sommario Nascondi sommario The Documents app for Android allows you to access the files stored in your ONLYOFFICE account on your mobile device. Using this app, you can view, create and edit text documents, spreadsheets and presentations, manage your documents as well as connect third-party cloud storages. You can provide different access types to your files and edit documents collaboratively with other portal users or share files via external links. ONLYOFFICE Documents app for Android Documents app for Android changelog Getting Started Overview Common operations for Android Manage files Open or create new files and folders Share files and folders Document Editor for Android Operazioni principali Navigate through your document Switch between editing modes Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Impostare parametri di pagina Inserire interruzioni di sezione Inserire numeri di pagina Insert footnotes Insert endnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Formattazione del testo Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Strumenti e impostazioni Modifica collaborativa dei documenti Protect documents with a password Spell-checking Use the Find and Replace function Download and print your document Visualizzare informazioni sul documento Spreadsheet Editor for Android Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Selective cell clear Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Ordinare e filtrare dati Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Modifica collaborativa dei fogli di calcolo Protect spreadsheets with a password Use the Find and Replace function Change spreadsheet settings Change regional settings Download and print your spreadsheet Visualizzare informazioni sul file Presentation Editor for Android Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Gestire diapositive Impostare parametri di diapositiva Change presentation theme Change slide layout Applicare transizioni Change slide background Preview your presentation Formattazione del testo Insert text Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Align your text in a text box Impostare interlinea di paragrafo Create lists Aggiungere collegamenti ipertestuali Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Strumenti e impostazioni Modifica collaborativa delle presentazioni Protect presentations with a password Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation Visualizzare informazioni sulla presentazione Overview Document Editor for Android Spreadsheet Editor for Android Presentation Editor for Android
