Chiudi Centro assistenza ONLYOFFICE Documents for Android Presentation Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Switch between editing modes Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert section breaks Insert page numbers Insert footnotes Insert endnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Change text wrapping Manipulate objects Strumenti e impostazioni Collaborative document editing Protect documents with a password Spell-checking Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Selective cell clear Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Protect spreadsheets with a password Use the Find and Replace function Change spreadsheet settings Change regional settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Insert charts Manipulate objects Strumenti e impostazioni Collaborative presentation editing Protect presentations with a password Spell-checking Use the Find and Replace function Change presentation settings Change application settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Add a hyperlinkEdit or remove the added hyperlink Add hyperlinks formattare caratteri Applicare stili di decorazione dei caratteri Applicare stili di formattazione Formattazione dei messaggi Come creare la base di conoscenza? Inserire un capolettera Insert text objects Insert text objects Inserire e formattare testo More articles Posta Impostare il tipo, la dimensione e il colore del carattere Impostare tipo di carattere, dimensione, stile e colore Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Aggiungere collegamenti ipertestuali Impostare il tipo, la dimensione e il colore del carattere Applicare stili di decorazione dei caratteri Aggiungere collegamenti ipertestuali inserire collegamenti Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Formattazione dei messaggi Come creare la base di conoscenza? Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali More articles Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali collegamenti esterni Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali More articles Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali collegamenti interni Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali More articles Aggiungere collegamenti ipertestuali Aggiungere collegamenti ipertestuali Add a hyperlink select the text passage that will get clickable and do the following: tap the icon at the top toolbar to open the new object insertion panel, switch to the Other tab and select the Link option, after that the Link settings screen will appear where you can specify the hyperlink parameters: Link type - select a link type you wish to insert: External link - this option is selected by default. Use it to add a hyperlink leading to an external website. Enter a URL in the format http://www.example.com in the Link field below. Internal link - use this option to add a hyperlink leading to a certain slide in the same presentation. Tap this option to select it, then return to the previous screen using the arrow on the left. Select the necessary Slide from the list: Next, Previous, First, Last, or a certain slide number. Display - enter a text that will get clickable and lead to the address/slide specified in the upper field. If you've selected a text passage before tapping the icon, the Display field will be filled with the selected text fragment. tap the checkmark in the upper right corner. To follow the added link, tap the Open Link option in the pop-up menu. Edit or remove the added hyperlink tap the Edit Link option in the pop-up menu and perform the actions you need: edit your data and tap the checkmark in the upper right corner to save the changes. use the REMOVE LINK button to delete the added hyperlink. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
