Chiudi Centro assistenza ONLYOFFICE Mobile web editors for Android Presentation Editor Document Editor complete documentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Projects for Android ONLYOFFICE Web Editors ONLYOFFICE Mobile web editors for iOS ONLYOFFICE Mobile web editors for Android Overview Manage files Open or create new files and folders Share files and folders Document Editor Operazioni principali Navigate through your document Select, cut, copy, paste text Undo/redo your actions Formattazione della pagina Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Formattazione del paragrafo Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Formattazione del testo Set font type, size, and color Apply font decoration styles Add hyperlinks Fillable forms Fill out OFORM fillable forms Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Create a Table of Contents Strumenti e impostazioni Collaborative document editing Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document View document information Spreadsheet Editor Operazioni principali Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operazioni con fogli Create or delete sheets Manage existing sheets Formattazione del testo di cella Set font type, size, and color Add hyperlinks Modifica delle proprietà di cella Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Modifica delle righe/colonne Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Operazioni sugli oggetti Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Strumenti e impostazioni Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Change app settings Macros settings Download and print your spreadsheet View spreadsheet information Presentation Editor Operazioni principali Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Lavoro con diapositive Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Formattazione del testo Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Change text indents Set paragraph line spacing Create lists Add hyperlinks Operazioni sugli oggetti Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Strumenti e impostazioni Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation View presentation information Glossario Video FAQ Generale Tecnologia Prezzi Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Set the line height within a paragraphSet the amount of space between paragraphs Set paragraph line spacing formattazione paragrafo Aggiungere bordi Allineare testo nella riga o paragrafo Modificare rientri di paragrafo Copiare/cancellare la formattazione del testo Inserire un capolettera Inserire interruzione di pagina Selezionare colore sfondo per un paragrafo Impostare interlinea di paragrafo More articles Impostare un livello di struttura del paragarfo Impostare le tabulazioni Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Insert line breaks Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Impostare interlinea di paragrafo Create lists Align your text in a text box Change text indents Impostare interlinea di paragrafo Create lists Creating a hanging indent interlinea Insert text objects Insert text objects Inserire e formattare testo Impostare interlinea di paragrafo Impostare interlinea di paragrafo Impostare interlinea di paragrafo Impostare interlinea di paragrafo Impostare interlinea di paragrafo More articles Impostare interlinea di paragrafo Impostare interlinea di paragrafo Impostare interlinea di paragrafo Impostare interlinea di paragrafo Set the line height within a paragraph put the cursor within the paragraph you need, or select several paragraphs, or the whole text in the text box, open the settings panel by tapping the icon at the top toolbar, or tapping the Edit option in the pop-up menu, switch to the TEXT tab and swipe up to see all the settings, tap the Line Spacing menu item, select the necessary line height value, close the text settings panel by tapping the arrow on the right. Set the amount of space between paragraphs put the cursor within the paragraph you need, or select several paragraphs, or the whole text in the text box, open the settings panel by tapping the icon at the top toolbar, or tapping the Edit option in the pop-up menu, switch to the TEXT tab and swipe up to see all the settings, in the Distance from Text section, use one of the following options: Before - to set the amount of space before the paragraph, After - to set the amount of space after the paragraph. Use the or arrows to decrease or increase the current value. close the text settings panel by tapping the arrow on the right. Download Teach your robot to read View and edit documents, spreadsheets and presentations of all popular formats Ti potrebbe essere d'aiuto anche... Chiudi
