At the Multitenancy page of the Control Panel, perform the following actions:
- click the NEW PORTAL button,
- specify a name for your second portal,
- if necessary, uncheck the Limit Control Panel functionality option,
When this setting is enabled, the PORTAL SETTINGS section will only be available in the Control Panel of the new portal. This section allows the portal administrator to manage the current portal only. If you disable this setting, full access to the Control Panel functionality will be provided. The COMMON SETTINGS section will also be available in the Control Panel of the new portal. This section allows the portal administrator to manage all portals.
- click OK to save the portal.
If you have not unchecked the Visit this portal after creating option that is selected by default, you will be redirected to the new portal that is available at the newportalname.domainname.com address.
The Portal Setup page will open in a new browser tab. Specify and confirm your password (By default, the password must be at least 8 but no more than 120 characters long), optionally change the email to create the Administrator account. You will not need to upload the license file as it is applied to all the portals at once.
To configure some individual settings for the new portal, go to the Portal Settings. You can adjust Customization settings (portal language and time zone, welcome page settings, team template, color scheme), select the necessary Modules and Tools to use, specify Security settings and SMTP settings.
