Control Panel
v3.5
ONLYOFFICE Control Panel changelog
Version 3.5.2
Release date: 02/29/2024
- Added the ability to restrict access rights to the application files for the Others group.
- Fixed issue with redirect to the portal main page when opening Control Panel after a day on Ubuntu 22.10.
- Fixed retrieving data error when opening the backup page.
- Fixed issue when backup with Mail is not performed after disabling and enabling encryption (added text about stopping services and the instruction to the Help Center).
- Fixed issue when features are not saved to the new tariff when setting a quota for the portal.
- Edited sources build.
Version 3.5
Release date: 03/14/2023
- Changed API methods for migration, implemented progressQueue.
- Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3.
- Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab.
- Added the ability to set the portal memory quota.
Version 3.1.1
Release date: 08/08/2022
- Fixed issue with file indexing.
- Fixed elasticsearch container errors when updating ONLYOFFICE Groups.
- Fixed issue with brand logos after updating in the Docker installation.
- Fixed texts and layout for the Migration feature.
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js, updated packages (transition to samlify for SSO);
- Added the
upgrade page with a proposal to upgrade to Enterprise Edition;
- Added the
activate page with a possibility to upload a license file;
- Transition to the new
samlify library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777;
- Fixed the
Invalid authentication token error which prevented from adding a user to the portal using the AD FS, in case the + or - characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown value or the ldap.domain value from the web.appsettings.config configuration file;
Sizelimit Exceeded error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute;
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth service;
Version 2.0.0
Release date: 05/25/2017
MVC to Node.js.
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Introduction
Authentification unique ou Single Sign-On (SSO) est la fonction qui permet aux utilisateurs de s'authentifier une seule fois et d'obtenir accès à plusieurs applications/services autorisés sans contrainte de renseigner à nouveau les informations d'identification.
Quand un portail web comprend plusieurs sections indépendantes (forum, chat, blogue etc.), une fois connecté à un service, l'utilisateur est automatiquement connecté aux autres et n'a plus besoin de se connecter aux différentes applications une par une.
La technologie d'authentification unique repose sur l'opération conjointe de deux applications: le fournisseur d'identité et le fournisseur de service (ci-après dénommées IdP et SP). L'authentification unique ONLYOFFICE SSO est réalisé uniquement en tant que fournisseur de service (SP). Plusieurs fournisseurs peuvent agir en tant que fournisseur d'identité (IdP), mais cet article examine la réalisation Services de fédération Active Directory (AD FS) .
Si vous souhaitez utiliser l'authentification unique pour connecter ONLYOFFICE Desktop Editors à votre ONLYOFFICE Workspace, désactivez Salles privées depuis le Panneau de configuration.
Configuration système minimale
La configuration système minimale inclut le logiciel qui a été dûment testé et a fait ses preuves avec ONLYOFFICE SSO:
- Windows Server 2008 R2, Windows Server 2016;
- AD FS version 3.0 ou version ultérieure.
Préparer la configuration de ONLYOFFICE Workspace SSO
- Installez ONLYOFFICE Workspace sur Docker ou bien toute autre version ultérieure prenant en charge SSO (AD FS est pris en charge à partir de Community Server v9.5).
- Ajoutez un nom de domaine, par ex. myportal-address.com.
- Sur votre portail, passez à Panneau de configuration -> HTTPS, créez et ajoutez le certificat letsencrypt pour le chiffrement du trafic (pour activer HTTPS sur votre portail).
Préparer AD FS pour la configuration de SSO
- Installer la version la plus récente AD DS (Service de domaine Active Directory) avec toutes les mises à jour et correctifs officiels.
- Installer la version la plus récente AD FS avec toutes les mises à jour et correctifs officiels.
- Vérifiez si les méta données AD FS sont accessibles au public. Pour ce faire,
- Dans Server Manager, accédez à Tools -> AD FS Management,
- Passez à AD FS \ Service \ Endpoints,
- Recherchez la ligne Federation Metadata dans le tableau. Le lien vers les métadonnées IdP construit selon le schéma suivant:
https://{ad-fs-domain}/{path-to-FederationMetadata.xml}
Vous pouvez également utiliser la commande PowerShell:
PS C:\Users\Administrator> (Get-ADFSEndpoint | Where {$_.Protocol -eq "FederationMetadata" -or $_.Protocol -eq "Federation Metadata"}).FullUrl.ToString()
En conséquence, votre lien doit ressembler à ceci:
https://onlyofficevm.northeurope.cloudapp.azure.com/FederationMetadata/2007-06/FederationMetadata.xml
- Pour vérifier que l'installation de AD FS s'est déroulée correctement, ouvrez le lien depuis votre navigateur. Il faut afficher ou télécharger le fichier xml. Copiez le lien dans le fichier de métadonnées xml car vous en aurez besoin lors de l'étape suivante.
- Assurez-vous que vous êtes connecté à votre Panneau de configuration ONLYOFFICE en tant que l'administrateur et cliquez sur l'onglet SSO dans la section Paramètres du portail sur la barre latérale gauche.
Il est possible d'enregistrer un seul fournisseur d'identité pour votre société sur le portail ONLYOFFICE.
- Activez l'option Activer l'authentification unique et collez le lien que vous avez copié depuis AD FS dans le champ URL vers le fichier XML de métadonnées fournisseur d'identité.
Appuyez sur le bouton flèche vers le haut pour télécharger des métadonnées fournisseur d'identité. Le formulaire Paramètres du fournisseur de service ONLYOFFICE sera rempli automatiquement avec les données depuis AD FS de fournisseur d'identité.
- Vous pouvez saisir n'importe quel texte dans le champ Légende personnalisée du bouton de connexion pour remplacer le texte par défaut (Single Sign-on). Ce texte s'affichera sur le bouton de connexion au portail avec le service d'authentification unique sur la page d'authentification ONLYOFFICE.
- Dans le sélecteur NameID Format, choisissez la valeur suivante: urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress.
- Dans la section Certificats publics du fournisseur d'identités \ Paramètres avancé, désactivez l'option Vérifier la signature des réponses d'authentification car elle n'est pas nécessaire à AD FS par défaut.
- Maintenant, il faut ajouter les certificats à Certificats du fournisseur de service. Vous pouvez générer des certificats auto-signés ou ajouter d'autres certificats.
dans la fenêtre Nouveau certificat, sélectionnez signature et chiffrement dans Utiliser pour car le fournisseur d'identité AD FS est réglé à vérifier des signatures numériques et à chiffrer des données.
Vous devriez obtenir presque les mêmes résultats:
- Dans la section Certificats du fournisseur de service \ Paramètres avancés, désactivez l'option Vérifier la signature des réponses d'authentification car elle n'est pas nécessaire à AD FS par défaut.
Il n'est pas nécessaire d'ajuster le formulaire Mappage d'attributs parce que nous allons configurer ces paramètres dans le fournisseur d'identité AD FS plus tard. Dans la section Paramètres avancés, vous pouvez activer l'option Masquer une page d'authentification pour masquer la page d'authentification par défaut et rediriger automatiquement vers le service d'authentification unique.
ImportantSi vous souhaitez restaurer la page d'authentification (pour pouvoir accéder à votre portal quand le serveur de votre fournisseur d'identité tombe en panne), vous pouvez ajouter la clé /Auth.aspx?skipssoredirect=true après le nom de domaine de votre portail dans la barre d'adresse du navigateur.
- Cliquez sur le bouton Enregistrer. La section Les métadonnées du fournisseur de service ONLYOFFICE s'affichera.
Vérifiez si les paramètres sont accessibles au public en cliquant sur le bouton Télécharger le fichier XML des métadonnées du fournisseur de services. Le contenu du fichier XML doit s'afficher.
- Copiez le lien vers les métadonnées du fournisseur de services ONLYOFFICE depuis le champ ID d'entité du fournisseur de service ( lien vers le fichier XML des métadonnées) où AD FS est installé.
Configurer le fournisseur d'identité AD FS
- Activez l'authentification forte pour des applications .NET.
Les applications .NET Framework 3.5/4.0/4.5.x peuvent changer le protocole par défaut pour TLS 1.2 en activant la clé de registre SchUseStrongCrypto. Cette clé de registre active le TLS 1.2 dans toutes les applications .NET 4.0.
Pour AD FS sur Windows Server 2016 et sur Windows Server 2012 R2 il faut utiliser la clé .NET Framework 4.0/4.5.x: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\v4.0.30319
Pour .NET Framework 3.5 utilisez la clé de registre suivante:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework\v2.0.50727] "SchUseStrongCrypto"=dword:00000001
Pour .NET Framework 4.0/4.5.x utilisez la clé de registre suivante:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework\v4.0.30319 "SchUseStrongCrypto"=dword:00000001
New-ItemProperty -path 'HKLM:\SOFTWARE\Microsoft\.NetFramework\v4.0.30319' -name 'SchUseStrongCrypto' -value '1' -PropertyType 'DWord' -Force | Out-Null
Pour en savoir plus, veuillez consulter cette page.
- Sur le panneau AD FS Management, sélectionnez Trust Relationships > Relying Party Trusts. Cliquez sur l'option Add Relying Party Trust... à droite. L'assistant Add Relying Party Trust Wizard s'affichera,
- Dans la fenêtre de l'assistant, activez le bouton radio Import data about the relying party published online or on a local network, collez le lien copié dans le champ Federation metadata address (host name or URL) des métadonnées du fournisseur de service ONLYOFFICEbet cliquez sur le bouton Next,
- Dans le champ Display name, indiquez le nom et cliquez sur le bouton Next,
- Sélectionnez l'option I do not want to configure multi-factor authentication settings for this relying party trust at this time et cliquez sur le bouton Next,
- Sélectionnez l'option Permit all users to access this relying party et cliquez sur le bouton Next,
- Vérifiez la configuration résultante et cliquez sur le bouton Next,
- Laissez l'option par défaut active et cliquez sur le bouton Close,
- Une nouvelle fenêtre s'affiche. Sous l'onglet Issuance Transform Rules, cliquez sur le bouton Add Rule...,
- Sélectionnez l'option Send LDAP Attributes as Claims dans la liste Claim rule template et cliquez sur le bouton Next,
- Saisissez un nom dans le champ Claim rule name. Sélectionnez l'option Active Directory dans la liste Attribute store et remplissez le formulaire Mapping of LDAP attributes to outgoing claim types selon le tableau ci-après. Une fois terminé, cliquez sur Finish.
| Attribut LDAP (sélectionnez ou saisissez pour ajouter plus d'options) |
Revendication sortante (sélectionnez ou saisissez pour ajouter plus d'options) |
| Given-Name |
givenName |
| Surname |
sn |
| E-Mail-Addresses |
mail |
| Telephone-Number |
mobile |
| Title |
title |
| physicalDeliveryOfficeName |
l |
- Dans la fenêtre Edit Claim Rules, cliquez sur le bouton Add Rule... encore une fois, sélectionnez l'option Transform an Incoming Claim dans la liste Claim rule template et cliquez sur le bouton Next,
- Saisissez un nom dans le champ Claim rule name et sélectionnez les options suivantes:
- Incoming claim type: mail,
- Outgoing claim type: Name ID,
- Outgoing name ID format: Email
Une fois que vous avez terminé, cliquez sur Finish.
Si la déconnexion AD FS ne fonctionne pas, il est donc recommandé d'ajouter une règle de revendication personnalisée (Custom Claim Rule) et remplacer {portal-domain} par votre domaine fournisseur de service et changer {ad-fs-domain} à votre domaine fournisseur d'identité:
c:[Type == "mail"]
=> issue(Type = "http://schemas.xmlsoap.org/ws/2005/05/identity/claims/nameidentifier", Issuer = c.Issuer, OriginalIssuer = c.OriginalIssuer, Value = c.Value, ValueType = c.ValueType, Properties["http://schemas.xmlsoap.org/ws/2005/05/identity/claimproperties/format"] = "urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress", Properties["http://schemas.xmlsoap.org/ws/2005/05/identity/claimproperties/namequalifier"] = "http://{ad-fs-domain}/adfs/services/trust", Properties["http://schemas.xmlsoap.org/ws/2005/05/identity/claimproperties/spnamequalifier"] = "https://{portal-domain}/sso/metadata");
- Cliquez sur OK,
- Pour que SSO fonctionne avec Intranet, il faut activer l'option Forms Authentication dans Edit Global Authentication Policy (menu contextuel menu AD FS / Authentication Policies),
- Ouvrez les propriétés de la partie utilisatrice que vous venez de créer et passez à l'onglet Advanced,
Sélectionnez l'option SHA-1 dans la liste Secure hash algorithm.
Vérifier le fonctionnement du fournisseur de service ONLYOFFICE avec le fournisseur d'identité AD FS
Se connecter à ONLYOFFICE sur le côté du fournisseur de service
- Passez à la page d'authentification ONLYOFFICE par ex., https://myportal-address.com/auth.aspx).
- Cliquez sur le bouton Authentification unique (le texte sur le bouton peut varier si vous avez indiqué un autre texte pendant la configuration du fournisseur de service ONLYOFFICE). S'il n'y a aucun bouton, l'authentification unique n'est pas activé.
- Si tous les paramètres sont correctement configurés, vous serez redirigé vers le formulaire de connexion au fournisseur d'identité AD FS:
- Saisissez votre identifiant et mot de passe de compte AD FS IdP et cliquez sur Sign in.
- Si vos identifiants sont corrects, vous serez redirigé sur la page d'accueil du portail (l'utilisateur manquant est créé automatiquement, ou les données sont mis à jour si le fournisseur d'identité a apporté des modifications).
Profils des utilisateurs qui sont créés via l'authentification unique
La possibilité de modifier les profils des utilisateurs qui sont créés via l'authentification unique est limitée. Les champs comportant des données fournies par le fournisseur d'identité sont marqués désactivé et on ne peut pas les modifier (par ex. Nom, Prénom, Email, Titre et Emplacement). On peut modifier ces données uniquement depuis le compte du fournisseur d'identité.
La figure ci-dessous illustre le menu Actions pour un utilisateur SSO:
La figure suivante illustre le profil d'utilisateur SSO à modifier:
Les profils des utilisateurs qui sont créés via l'authentification unique seront indiqués à l'aide d'icône SSO pour les administrateurs du portail.
