Connect the OneDrive service to use the connected cloud storage as a third-party resource when creating backups or public rooms.
Creating authorization keys
In the cloud version, the authorization keys parameters for OneDrive are set up automatically.
In the server version, you will have to setup authorization keys for OneDrive. Follow these steps:
- Go to Microsoft Azure.
- Sign in to your account.
- Сlick the New registration button at the App registrations page.
- Enter your application Name.
- Choose the platform (Web) and enter "https://service.onlyoffice.com/oauth2.aspx" in the Redirect URL field.
- Click the Register button at the bottom of the page;
- Copy or write down the
Application (client) ID displayed at the Overview page.
- Switch to the Certificates & secrets section on the left.
- Click the New client secret button.
- Enter the description and click Add.
Client secret displayed in the Value field.
Connecting OneDrive to ONLYOFFICE DocSpace
- In the server version, click the
menu in the lower left corner and select the Settings option.
- Switch to the Integration tab.
- In the Third-party services section, click the sliding button to the right of the OneDrive logo.
- Enter your keys and click the Connect button.
To store your DocSpace data backup in OneDrive,
- Go to the 'Backup' section (DocSpace Settings -> Backup -> Third-party resource).
- Select OneDrive as the desired storage and click the 'Connect' button.
- Choose your account, grant the access to ONLYOFFICE application and click 'Create copy'.
To store your public room data in OneDrive,
- Go to the Rooms section on the left.
- Use the New room button in the upper left corner or the
Plus icon above the list of rooms.
- Select the Public room.
- Enter the room name, add tags, upload an image.
- Turn on the Third-party storage switcher.
- Select OneDrive from the list and click Connect.
- In a new window, specify the connection URL, your login and password, and click Save.
- A new folder for storing this room’s data will be created in the connected storage. If necessary, uncheck this option and select the already existing folder in the connected storage.
- Click Create.
For more details about creating rooms, read this article.
